Will these heads make the power? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-10-2012, 09:34 AM
Ok so as some of you may know i was considering the assualt 210cc heads. I called them up and they said that head flows averages 256 int. 197 ex. @. 600 lift. First im guessing i can run a matched duration cam with this head right? Second What kind of power is this head capable of? Im looking at 10.5:1 cr in a 383. Its a 64cc head.
Old 12-10-2012, 09:42 AM
I know ive gotten cam opinions already. But withis data what cam would sound good. Power is all that matters. Track car only. I was looking at a comp cam with 306 duration and .555 lift. Seems to be about the max on the low compression.
Old 12-10-2012, 09:44 AM
Originally Posted by F-BIRD'88 View Post
A very rough estimate of the power you can make based on just those two peak flow numbers and a 10.5:1cr is 474HP. Remember this is very rough and you have to use all the nessessary supporting parts to make it happen. ( right cam, inake big carb, good headers)
Usually thee cheapy heads can use a good clean up from the out of the box form.
That estimation would be great to hit. What cam, carb, intake, headers do you recommend?
How much power will should i make? Raptorus1 Hotrodding Basics 9 04-05-2012 10:33 AM
081/416 heads that make afforable power. FKR Engine 15 12-22-2010 08:45 PM
Can peanut port heads make power up to 5500rpm? turchiac Engine 4 11-11-2010 08:47 AM
how much power should this make? dboyett38666 Engine 2 03-13-2006 06:44 AM
How much power will these heads make? jeff of nc Engine 2 11-17-2002 08:10 AM
