Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Will these mounts clear stock SBC clamshell's?
Old 05-21-2013, 11:09 AM
matt167 matt167 is online now
Wiki Edits: 31
Trying to figure out which mounts I'm going to use to plant the 350 on the Ford Ranger crossmember. These mounts have been used for a SBC swap but only with the matching solid engine mounts. From what I have read, these replace the stock mounts for most X and A bodies thru the 70's. They fit on a Ford Ranger chassis quite well..
Other suggestions as to mounts? I know I can make mounts that fit, but without a steel yard close by anymore, paying what they want at the retail mart's/hardwares for small sections defeat's the cost benefit.
Moroso 62630
