Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Will these mounts clear stock SBC clamshell's?
Old 05-22-2013, 10:08 AM
matt167 matt167 is online now
Wiki Edits: 31
I 'think' they will work with the stock engine mounts for an early 70's Chevy Nova.. After '73 the rubber isolator attached to the frame mount and the solid mount attached to the engine and that setup probably would not work for me..
They are modeled after the stock solid chassis mounts, so it makes sense they work with the stock engine mounts. Summit lists them as only working with solid mounts and another supplier said they did not know. They look right tho
