Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Will these mounts clear stock SBC clamshell's?
Old 05-22-2013, 01:15 PM
ericnova72's Avatar
ericnova72 ericnova72 is offline
More for Less Racer
The frame mount you have pictured is for use with the stock 1975-up block mounted steel "clamshell" mount . It replaces the stock encapsulated rubber mount on the frame of 1975-up GM cars and trucks, making a solid connection.
It won't work with earlier pre-1974 mounts which have the rubber part on the engine, as shown in the second post above. The width will be incorrect.
