Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Will these mounts clear stock SBC clamshell's?
Old 05-22-2013, 02:34 PM
ericnova72's Avatar
ericnova72 ericnova72 is offline
More for Less Racer
Originally Posted by matt167 View Post
Crap. Will the stock '75- up stock frame pads work with the engine mount they have listed to work with that frame pad? P/N 62515. Jegs shows the pic as not being the actual part but gives the dimensions. It doesent seem like they will work. I just know solids is not going to be good in the light chassis it's going into
All the mounts on this list are meant to replace the pre-'75 rubber mount that is on the block(like in your post #2)...not the one on the frame. They attach to the stock factory solid frame stands on the 1960's-early 1970's Chevy cars and trucks. Meant to give a solid-to-solid connection for racing.
All the Moroso mounts are for solid-to-solid connections...for racing, replacing any rubber connections.
