Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Will these mounts clear stock SBC clamshell's?
Old 05-22-2013, 02:38 PM
ericnova72's Avatar
ericnova72 ericnova72 is online now
More for Less Racer
Originally Posted by matt167 View Post
Trying to figure out which mounts I'm going to use to plant the 350 on the Ford Ranger crossmember. These mounts have been used for a SBC swap but only with the matching solid engine mounts. From what I have read, these replace the stock mounts for most X and A bodies thru the 70's. They fit on a Ford Ranger chassis quite well..
Other suggestions as to mounts? I know I can make mounts that fit, but without a steel yard close by anymore, paying what they want at the retail mart's/hardwares for small sections defeat's the cost benefit.
Moroso 62630
This mount bolts to the frame(in place of the stock rubber isolator mount), and fits in the stock GM steel clamshell bolted to the block on '75-up Chevy's. Gives a solid-to-solid connection.
