Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Will these mounts clear stock SBC clamshell's?
Old 05-22-2013, 03:37 PM
matt167 matt167 is offline
Wiki Edits: 31
I understand what they are for. I was just trying to see if I can mix and match the Moroso engine mounts ( either frame side or engine side depending ). It looks like nothing will work.. Only way to make any of this work is to find the factory engine side mount for a '75+. If they are reproduced it would be a +. Then I can use the parts store frame pad for a '75+... Probably better off with a weld in setup at this point tho, I liked the idea of the Moroso mounts because they fit on the crossmember and could be bolted in.
