Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Will these mounts clear stock SBC clamshell's?
Old 05-22-2013, 09:20 PM
496CHEVY3100's Avatar
496CHEVY3100 496CHEVY3100 is online now
Built Not Bought
Last journal entry: 53 ad3100
I have the mount matt167 has in the picture turned flatside down and welded to my frame and clamshells on the engine.i bolted clam shell to block then put a thtu bolt in and set engine where I wanted it tack welded to frame then pulled engine and finish welding ,but my front clip was off.easy to get to , You WILL get a little buzzing in sterring wheel if that is a problem you might want an isolater.
