The problem is not the spring. its the inside diameter of the inner damper.
The spring choice does not deal with the retainer to seal/guide boss lift clearance with high lift cams. You still need to shorten the guide boss. and or use special non stock retainers. |
Ok guys thanks. Im just gonna buy that kit through Alex's Parts that gaurantee no machine work needs done to obtain .550 lift. I think that would probably be about the limit on lift numbers with vortecs any and that would be fine with me.
I am going to get new studs but is there a way that I can get the pressed studs out myself. Also I have some 2.02 and 1.60 valves I am going to use. How much of a difference does those bigger valves have over 1.94 and 1.50 valves.
if you plan to get new rockers? turn a rocker upsidedown reistall the jam nut and washer with an impact gun until the studs pull out.
the 202 valves are not worth the effort to install in vortec heads |
| differnce in valve springs. will flat tappet springs work with a roller cam? | hemiguy2009 | Engine | 1 | 01-31-2011 03:19 PM |
| Photo of 906 Vortec ex valve seats? | staleg | Engine | 3 | 11-09-2009 01:35 AM |
| Beehive Springs/Valve Spring Micrometer | ssmonty | Engine | 5 | 10-27-2007 04:41 PM |
| Will this cam work with stock vortec valve springs? what is the accepted max lift? | Warrant | Engine | 1 | 11-30-2006 01:56 PM |
| valve springs seats or shims??? | 69elcaminoss | Engine | 3 | 03-27-2004 09:22 PM |
