It will swap, it may run rich on the 305 because the 350 TBI has bigger injectors than the 305 TBI would have had. An adjustable fuel pressure regulator may be enough to get it to a good usable point.
well I think the intake from the 350 is more flat, the bolts on the intake from the 305 look like a different angle. the 350 still runs so I dont want to take it off until I do the swap. that is a good point about running rich thank you for that. I guess I should say I dont know it the 350 intake will bolt on to the 305 block and heads? I will take what ever advice anyone has thanks
If the bolts on the 305 intake area at a different angle(I am assuming you are talking about the center pairs) then the 305 must not have 1986 heads on it or is not an 1986 engine. All SBC heads 86-95 have the same bolt angle, prior to that(55-85) is different(all are the same angle, centers not different) and 96-up have the vertical Vortec pattern(only 8 bolts, not 12)
So the 305 is out of an 86 gmc, it could still have some things from 85. That may be one of them, just depends on what time of year the truck was made.
Ok now lets say the block is 85', is there a way to get my intake 91' onto that block? would my heads from the 350 fit on the 305? Sorry Im just dont know technicalities on engines, I can diagnose and fix them but dont have alot of experience with what you can mix and match? Thank you though. |
Is that a problem? If the original 305 heads were 58cc, and the 350 heads are 64cc swirl ports, the difference will be about .5:1. With the 64cc heads the CR will be about 8.15:1. The intake can be modified (center bolt holes elongated, using special washers to compensate for the change in angle) to fit the OEM intake onto the older style heads, I THINK. There are adapters for putting a TBI throttle body onto a 4-bbl. intake, so you could use a Performer (as an example) made for the 305 heads, mount an adapter, then mount the 350's TBI throttle body to that. |
I think the 350 intake is more flat meaning the bolts are more vertical
on the 305 where the intake sit on the heads that is more vertical and the bolts are more horizontal. sound right? thats my major problem I wouldnt be able to put a gasket on. thank you |
They make aftermarket adapters as stated earlier, on the 454 throttle body GM used an adapter and put it straight to the 4bbl intake but it is ugly!
Look a little closer at what you have, specifically just the four center bolts, if angles match there they will interchange. 305 or 350 manifolds are not bigger or smaller than each other physically. |
91 intake to 86 heads
I think most of 86 heads have the later angle on the 4 center bolts, I have a quad intake in the shop that has the later pattern which off an 86. Either way you can order an inexpensive kit to make it work. We make our own; it takes about 45 minutes to cut four pieces of small pipe on the angle you need and then cut out the holes a bit and go. I have 993 heads on a later model TPI car. It's easy
'87 for sure had the later angled intake bolts and centerbolt valve covers. |
Like I noted, all he has to do is look at the bolt angles of the 4 center bolts to know if the swap will work, and even that can be overcome with a die grinder at assembly as others have said. |
| will throttle body work on GM performance intake | acarpenter | Engine | 6 | 08-20-2010 07:56 PM |
| Torque link intake manifolds? | xxllmm4 | Engine | 10 | 06-12-2009 07:20 AM |
| 350 throttle body question | old40ford | Engine | 2 | 06-12-2006 06:41 PM |
| Improving mileage on 350 throttle body | macx | Engine | 9 | 01-31-2005 09:41 PM |
| Will this work? Chevy 305 Throttle Body w/ Chevy 350 | aberg12012 | Engine | 9 | 05-07-2004 12:28 AM |
