will a Trans AM differential work in a g-body rear end? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-02-2011, 05:38 PM
the differential has 26 spline axles and is a 7.5 ring gear
Old 08-02-2011, 06:46 PM
seanross's Avatar
its the same guts (axle spline count might be different) but a g body is a coil spring car and firebird are a leaf spring car. if the width is the same you could mod one to fit but probably wouldnt be worth the work.
not sure what you classify as differential or rear end but the cairiers are the same. i beleive 28 spline axles exist so if you run into that then you need to use your old spider gears.
Old 08-02-2011, 06:49 PM
its just the differential, no housing or anything.
Old 08-02-2011, 06:51 PM
seanross's Avatar
edited my original post
Old 08-02-2011, 06:54 PM
yes i mean carrier,oops. he said he was running 26 pline axles.
Old 08-02-2011, 06:56 PM
seanross's Avatar
i think the 28s were on the s10's im sure if i looked it up i would know for sure but it sounds like you got it figured.
Old 08-02-2011, 06:57 PM
seanross's Avatar
if its a transam you should buy his rear disc brakes and backing plates
F-body differential question Mullet1 Transmission - Rearend 3 07-12-2010 08:10 PM
Differential gears to match Saginaw trans. Caballerokid Transmission - Rearend 7 05-06-2010 05:38 AM
will an offset rear differential work? matt167 Transmission - Rearend 3 03-10-2010 08:45 AM
Lill Bit Of Body Work And Chassis Work... hotrod389 Hotrodding Basics 7 05-23-2007 07:12 AM
4-Link differential & Trans angle- with Pic 68NovaSS Transmission - Rearend 12 05-08-2007 07:05 AM
