will a used t-5 trans out of a 1991 s-10 work with - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-02-2008, 07:25 AM
Mustangsaly's Avatar
will a used t-5 trans out of a 1991 s-10 work with a 350HP SBC ? what needs to be done to bolt it up ? I'm thinking of bolting this up in a early 70s Camaro.
thanks
Old 07-02-2008, 07:36 AM
SSedan64's Avatar
Check this thread.
S10 t-5 scarce?
Old 07-02-2008, 02:00 PM
is there a 5 speed manual tranny that can be used behind a good SBC V8 thats out of a donor vehicle ?
thanks
Old 07-02-2008, 08:08 PM
judd55's Avatar
Get a WC T-5 out of a Camaro/Firebird and convert tailshaft and speedo to Manual drive or get conversion box Cable X
327 '89 Trans Am GTA suggestions 3rdGenFreak Engine 2 06-29-2007 07:45 PM
1982 Trans Am W/ BW T 10 - using torque arm Trans Am Tony Transmission - Rearend 1 04-23-2007 06:39 PM
Ideas for "MY" Trans AM 3rdGenFreak Hotrodding Basics 0 12-10-2006 02:09 AM
I think it needs a little block work? 10 grit? rrmccabe Body - Exterior 8 08-16-2005 01:05 PM
i found a trans.... will it work?? help!! montea Transmission - Rearend 6 02-22-2004 03:02 AM
