will the valve springs work? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-23-2003, 07:19 PM
the ernster's Avatar
Question will the valve springs work?
would the valve springs on a set of stock 283 power pack heads hold up to a lunati 292 cam or will i have to change them? <img src="graemlins/evil.gif" border="0" alt="[evil]" />
Old 04-23-2003, 08:33 PM
BOBCRMAN@aol.com's Avatar
Post
stock power pack springs were for less than .450 lift, not only change them but check for guide-retainer clearance, you will probably have to shorten the guide.
Old 07-05-2003, 07:20 PM
GRAVOIS's Avatar
Thumbs down swap
Why risk it.
Old 07-05-2003, 09:20 PM
NAIRB's Avatar
Ernster, you can upgrade valve springs on a Chevy so cheap it will make you sick. No need to use the stockers, you can buy them as cheap as 15.00 for Z-28 type springs, which will handle around .520 lift depending upon what height you install them at, and yes make sure you spot your guide boss down a little to allow for retainer to seal/guide boss clearance.
