Will this work? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-01-2007, 09:29 PM
Wayne
Last journal entry: Test Fit of "new" Engine
Will this work?
Suspension & Front-End Gurus out in HR Land - I have a front suspension/ crossmember from a '76 Toyota pickup that bolted onto the original Toyota chassis - I didn't have to cut it out. It's 'C' clamped to the frame rails of my '36 Hudson Terraplane checking the fit. Looking at the photos I've attached, will this work or not?
The Toyota chassis went straight to the front and then both frame rails turned out where this crossmember bolted on. Because of the mounting of the front fenders, I can't spread my frame rails to match the Toyota crossmember.
If it will work, I know I have to weld some bracing under it so I can bolt it to my Hudson chassis - after I box my rails. I also want to put some 1/2-inch pipe sleeves inside the frame rails for the bolts to go through to keep the frame from squeezing down from the pressure of the bolts (or is this overkill?).
The engine is a 3.8L V6 Ford. I will also have to modify the inner fenders so everything will fit.
Any and all help will be greatly appreciated.
Wayne
Name:	IMG_1777 (Small).JPG
ID:	25223   Click image for larger version
Name:	IMG_1783 (Small).JPG
ID:	25224   Click image for larger version
Name:	IMG_1780 (Small).JPG
ID:	25225   Click image for larger version
Name:	IMG_1781 (Small).JPG
"a little over" turns into $4500 over for paint job bullheimer Body - Exterior 128 02-06-2006 09:57 AM
89 honda accord, headlights wont work...and... Rubberman2003 Electrical 6 02-10-2005 06:26 AM
Work. coldknock Hotrodders' Lounge 6 11-21-2004 05:57 PM
Stuff I work on at work :) esears Hotrodders' Lounge 6 09-29-2003 02:08 PM
Ever work on the impossible? johnsongrass1 Hotrodders' Lounge 16 08-20-2003 02:59 PM
