Will this work? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-10-2008, 09:13 AM
Will this work?
My Uncle recently started doing a pro street corvette and I was looking at it the other day. He has a ladder bar set up and the car is tubbed however the coil over shocks and springs are in the front of the axle/rear end housing not the rear where mine and almost everyone elses are. Is this going to even work right? I just didn't know if it was going to be ok or if I should say something to him.
Old 04-10-2008, 09:41 AM
boatbob2
springs.....
Hi,i have always put the springs to the rear of the axle.
Old 04-10-2008, 10:04 AM
84 Monte Carlo's Avatar
Auto Tech
Last journal entry: this car is for sale
check this out http://www.hotrodder.com/projects/ba.../backhalf.html coil overs in the front real nice car and fast
Old 04-10-2008, 10:09 AM
Thanks for that article that's actually a very nice Nova. Mine are to the rear but maybe the guy building the nova and my uncles car have a reason they did it that way?
Old 04-10-2008, 11:20 AM
Auto Tech
Yea,I don't know seems like alot going on in the front
Old 04-10-2008, 11:44 AM
I can see where it would work I guess then again I can see where it might not. I called Chris Alston Chassis Works and their rep said it shouldn't affect the car and that's how all the old school guys used to do it. He said there is nothing wrong with that… they just fit better on a real narrow car behind the rear.He also said it does make adjusting the coil overs kind of a pain in the *** but it also leaves more room to work with wheelie bars if they are being used.
Old 04-15-2008, 08:41 AM
novajohnb's Avatar
It'll go, or it'll blow...
It will work just fine. Be aware that spring rates will need to be higher than if the springs were behind the axle to keep the same ride quality.
Going from behind the axle to in front of the axle, reduces the motion ratio of the springs and shocks.
"a little over" turns into $4500 over for paint job bullheimer Body - Exterior 128 02-06-2006 08:57 AM
89 honda accord, headlights wont work...and... Rubberman2003 Electrical 6 02-10-2005 05:26 AM
Work. coldknock Hotrodders' Lounge 6 11-21-2004 04:57 PM
Stuff I work on at work :) esears Hotrodders' Lounge 6 09-29-2003 01:08 PM
Ever work on the impossible? johnsongrass1 Hotrodders' Lounge 16 08-20-2003 01:59 PM
