will it work - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-29-2008, 09:40 AM
will it work
I have a 88 camaro that came stock with a 2.8 MPI and i was wondering if a 305 TBI from a 93 GMC will work with a ECM swap or would I have to change the harness also? i was told i could change the pcm/ecm but i got to looking at the wiring harness and it is set up for six injectors and not two is there a pig tail or is there another harness piece that will hook up to the existing harness? Or do i need to pull both pcm's and harnesses?
Old 10-29-2008, 10:13 AM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi
The 2.8 is a V6, six cylinders
the 5.L is a V8, eight cylinders
If it can be don, I don't know how to do it.
Good luck,
Rich
Old 10-29-2008, 10:25 AM
1931 steve's Avatar
Last wiki edit: How to rebuild an engine Last photo:
Wiki Edits: 4
You will need to change the wire harness also, everything is different. You can buy a aftermarket harness that makes things easier, but you can also use the factory harness, just need to sort through what you need in that (OEM) harness.
Steve
"a little over" turns into $4500 over for paint job bullheimer Body - Exterior 128 02-06-2006 08:57 AM
89 honda accord, headlights wont work...and... Rubberman2003 Electrical 6 02-10-2005 05:26 AM
Work. coldknock Hotrodders' Lounge 6 11-21-2004 04:57 PM
Stuff I work on at work :) esears Hotrodders' Lounge 6 09-29-2003 01:08 PM
Ever work on the impossible? johnsongrass1 Hotrodders' Lounge 16 08-20-2003 01:59 PM
