Will it work? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-05-2013, 08:29 PM
Will it work?
Re doing an 88 gmc sb 4x4. Have some 6" scat rods and .040 over flat tops. Will the trucks computor and emissions work properly? Need some feed back. Thanx Guys Fourspeed
Old 04-06-2013, 08:26 PM
If the piston and rods are the only change the computer will never know. It would be a good idea to rebalance the rotating assembley.
Old 04-11-2013, 01:24 PM
Thanx for the info. Thouhgt that would be the case but wanted to be sure. Blk cleaned and bored,vortech heads,balanced rotate ***, and comp cams cam and valvetrain *** performance/tow. Also scat 6" rods with speedpro .040 machined flat tops.
Old 04-11-2013, 01:36 PM
techinspector1's Avatar
Wiki Edits: 326
Originally Posted by fourspeed View Post
machined flat tops.
Just curious, what does this mean?
Lill Bit Of Body Work And Chassis Work... hotrod389 Hotrodding Basics 7 05-23-2007 07:12 AM
Do they really work fat40 Engine 7 02-04-2006 07:12 AM
porting 882s at home,no machine work, rebuild, will it work? what are they capable of Warrant Engine 6 12-27-2005 12:14 AM
so where do you work? 53fordguy Hotrodders' Lounge 66 10-23-2004 05:18 PM
Stuff I work on at work :) esears Hotrodders' Lounge 6 09-29-2003 01:08 PM
