will it work? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-26-2005, 11:30 AM
will it work?
Hello people,
I found a complete hub to hub 1984 corvette front suspension that i was thinking of installing on my 1940 chevy master delux.Before i buy the thing, I'd like to know first of all if this installation is at all fasible.Another question would be :How hard would such a swap be.Can I just take the set up and weld it under the frame (I'll be using the stock chassis).If not what will I have to do to make it work?I saw that Progressive automotive advertises a suspension set up designed on corvette components but looking well at the pitures on their site, the cross member seems to be after market.Will I be able to use the Corvette cross member? Is there gonna be any cutting of the frame?I hope someone can help me with all this ...Thanks in advance.
Black Knight
Old 11-26-2005, 12:56 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
The first thing I would do would be some measureing, Measure the track width on the front of your car then measure the track width on the Corvette front end. If the Corvette is too wide then your tires and wheels will not fit up under your car properly. Other than that I do not know what you would have to do.
Old 11-26-2005, 02:14 PM
thanks Henry
I'll start out by doing just that.By the way,did you see the trucks pictures?
Black Knight
"a little over" turns into $4500 over for paint job bullheimer Body - Exterior 128 02-06-2006 09:57 AM
Work gripe. Share yours? killerformula Hotrodders' Lounge 25 11-22-2004 05:01 PM
Work. coldknock Hotrodders' Lounge 6 11-21-2004 05:57 PM
Stuff I work on at work :) esears Hotrodders' Lounge 6 09-29-2003 02:08 PM
Ever work on the impossible? johnsongrass1 Hotrodders' Lounge 16 08-20-2003 02:59 PM
