Will z28 springs fit? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-15-2012, 02:24 PM
clance54's Avatar
I have 186 casting heads and need to know if z28 springs will fit. Thanks ahead of time.
Old 02-15-2012, 02:53 PM
BOBCRMAN@aol.com's Avatar
Yes the springs most places sell as Z28 will work. Carefully set up spring height.
Old 02-15-2012, 04:14 PM
clance54's Avatar
What do I need to watch out for when setting the spring height?
Old 02-15-2012, 09:12 PM
You did not state the cam specs. Most of the aftermkt springs are 90-100 lbs on the seat. Usually at 1.72" installed height. Check for coil bind and guide/seal interference.
differnce in valve springs. will flat tappet springs work with a roller cam? hemiguy2009 Engine 1 01-31-2011 03:19 PM
81 c10 front coil springs swap for s-10 springs campracing Suspension - Brakes - Steering 3 10-05-2009 04:51 PM
air springs JEREMY067390 Suspension - Brakes - Steering 0 10-07-2007 09:13 AM
Re arc springs 2" lower, or use 1" springs and blocks? Ripped Suspension - Brakes - Steering 4 10-23-2005 12:52 PM
Air vs. Springs rostocker Suspension - Brakes - Steering 5 09-27-2005 11:14 AM
