willys pickup tranny swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-01-2011, 10:29 AM
#1 Today, 11:10 AM
gcollins
I have a restored willys pickup with a 350 sbc with a 4 speed chevy truck tranny. Want to swap to a 305 sbc with a 700r4 with probably the 208 case with the right hand drop. My question is, I have found a MINT 305 out of a s-10 with a 2x4 700r4. Extremely low miles, etc. Can the 2x4 700r4 be converted to adapt the 4x4 case. What all is involved here. I know an adapter from Advanced adapters for sure and ofcourse the 4x4 case. The 4 speed currenty has the d-20 case adapted to it. Thanks all Gary
Old 01-01-2011, 10:44 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
interesting copy n paste you did there.
the 700 / 4L60 trans out put shaft can be swapped from a 2x shaft to a 4x4 shaft. Dirt simple deal for someone with knowledge of this transmittin series
Make sure the t-case is correct for the 700 / 4L60 trans
Old 01-01-2011, 12:24 PM
transfer case
What case would be correct Most of the mid chevy trucks had the 208 I need the 208 that comes out passenger side. What all will I need other than the 4x4 output shaft If I were getting the 4x4 700r4 with the 208 case I wouldn't need anything right ?? This tranny is 2x4 with extremely low miles and the 305 with it is MINT I can find a 208 correct side case pretty easy Thanks for your help !!!!! Your the man !!!!
willys pickup tranny swap gcollins Hotrodding Basics 1 01-01-2011 10:15 AM
chevy pickup motor and tranny swap rebel till death Transmission - Rearend 2 05-29-2009 07:39 PM
willys pickup bruce mckenzie Introduce Yourself 2 07-18-2007 09:59 AM
1941 Willys Pickup DarellGLewis General Rodding Tech 14 12-02-2004 11:13 PM
Willys pickup suspension maddog200485 Suspension - Brakes - Steering 2 10-22-2004 02:28 PM
