Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Willy's re-build
Old 10-05-2012, 07:40 PM
greazyball greazyball is offline
Last journal entry: studebaker m5
i used a 9in ford rear axle from a 1979 mercury cougar in my 55 willys truck.The width is 59in backing plate to backing plate.It appears you are wanting to use a GM axle,but in a pinch you could re-drill the lugs on the ford axle to a GM lug pattern
