Willy's re-build - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Hotrodders' Lounge> Introduce Yourself
Old 10-04-2012, 11:24 AM
Willy's re-build
I have a '53 Willy's pickup I've been wanting to re-build for some time now. Now that I have the time, and some money, I'm not sure what to do with it. I had wanted to make a regular 2wd pickup to drive around using parts off of my '88 Chevy. Turns out the rear axle from the Chevy isn't wide enough to match the Willy's frame. I need something at least 58''. Should I just make a street rod using a Pontiac axle? Thoughts?
Old 10-05-2012, 01:34 PM
RWENUTS's Avatar
Welcome Mohawk!!!
Got pics of your Willy's!!
Lots of rearends out there that wide or wider.
Old 10-05-2012, 07:40 PM
Last journal entry: studebaker m5
i used a 9in ford rear axle from a 1979 mercury cougar in my 55 willys truck.The width is 59in backing plate to backing plate.It appears you are wanting to use a GM axle,but in a pinch you could re-drill the lugs on the ford axle to a GM lug pattern
Old 10-10-2012, 07:47 AM
I don't have any pictures as of yet. I have everything stripped down to the frame. Thanks for the suggestions. I have a lot to look into.
G-willy G-Willys Introduce Yourself 2 01-27-2007 01:13 PM
Hey Willy's... 38 special Hotrodders' Lounge 5 11-07-2005 11:51 PM
33 Willy 39 OLDROD Hotrodders' Lounge 11 05-21-2004 11:46 PM
Willy's36, I could use your help scott011422 Engine 1 10-10-2003 01:35 PM
Willy's36 Halloweenking Hotrodders' Lounge 1 03-21-2003 12:54 PM
