Wilwood Front Brakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-03-2007, 08:17 AM
Hi,
I'm planning brakes for a streetrod project.......and for a 4000# streetrod, will the standard Wilwood 11" rotor , 4 piston caliper front brake setup provide for good braking, or does the upgrade ( + $2000)for the Wilwood 13" rotor, 6 piston caliper make sense.
Please let me know your thoughts......
Thanks
Old 11-03-2007, 09:13 AM
Dugg's Avatar
My compass doesn't point North
When it comes to brakes I use the same formula I used to use when mixing nitro for my old fuel dragster... if some is good, more is better and too much is just right.
Old 11-04-2007, 03:23 PM
427v8's Avatar
C6, the C5 of tomorrow
Wiki Edits: 7
the 11" is pretty small, how thick is the rotor?
The Dodge caravan uses a 11" rotor about ,75" thick and is just barely enough.
If the Wilwood setup is using 1.25" rotors it should be fine unless you drive it hard...
13" is plenty!
Old 11-04-2007, 04:08 PM
302 Z28's Avatar
For a 4000# car I would go with the upgrade. My 34 weighs about 3000# and I have the Wilwood 11" rotors and four piston calipers all the way around, they work great.
Vince
No front brakes Key Suspension - Brakes - Steering 6 08-18-2007 02:46 PM
Front disc brakes 50 Cadillac stock spindles badazz55 Suspension - Brakes - Steering 2 11-23-2005 04:20 PM
disk brakes front 40 chevy B Butcher Introduce Yourself 3 11-18-2005 03:33 PM
what are front disk brakes like without a power booster? brian400ex Suspension - Brakes - Steering 5 02-28-2003 04:31 PM
Front brakes PHAT 40 Suspension - Brakes - Steering 4 01-13-2002 12:39 PM
