Hi folks
I tried to contact willwood per email but they don't answer me...
I come from europe and can't use the helpline, so i try my luck here :welcome:
I would like to know if this master cylinder from Wilwood will work on my stock setup. I have front disc and rear drums with following lines:
2 front lines 3/16"
1 rear 1/4" with tee fitting on the axle into two 3/16" lines
The Wilwood proportioning valve have 3 exits size 3/8-24 with an SAE inverted flare for standard 3/16” line.
The front lines are not an issue but the rear line with the 1/4" size. My thoughts are: Is there a opportunity to connect the 1/4" line from the rear? Or will a new 3/16" brake line do the job?
Thanks for any advice
kind regards
Robert
2 front lines 3/16"
kind regards
Robert
