Windage Tray 400 SBC - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-10-2008, 10:17 AM
I am going to add a Milodon "DIAMOND STRIPPER" windage tray to my 406, but am confused as to which model I need to run when using the stock oil pan.
Milodon indicates;
- model 32250 for SB Chevy - 350 & 400
- model 32255 for SB Chevy - 350 & 400, with full length pan
Jegs and Summit information just adds to the confusion.
Is anyone running one and if so which model?
Old 08-10-2008, 10:32 AM
edge's Avatar
Time is short, are you ready?
I have a model no. 32250 in my 383.
As far as a stock pan, I'm not sure. I am using a Moroso no. 20190 pan.
I had to modify it so that the dipstick wouldn't drag on it. This was giving me false readings which eventually lead to problems
You can see more of my build here: http://www.edgesz28.com/edgesz28/engine.htm
Best of luck, Ed
Old 08-10-2008, 11:16 AM
Thanks for the heads up on the dip stick Ed, I will double check that during install.
Old 08-10-2008, 02:17 PM
TorkMonster400's Avatar
uninteresting default message
Last journal entry: A couple of pics of the car
Wiki Edits: 4
Don't waste your money on the diamond stripper, same thing only cheaper.
http://www.speedwaymotors.com/p/1754...temNo=91015100
I have this same part, it is just like the Diamond stripper, only you don't have to use special milodon bolts. I hope this helps. So Far this has been a great part minus a little custom fit.
ID:	31719   Click image for larger version
ID:	31720   Click image for larger version
Old 08-12-2008, 08:09 PM
With being in Canada, I can get the Milodon from a speed shop down the street, the Speedways looks very close though and I am sure works just as well.
Anyone have the Milodon tray in a 400 block with a stock pan?
what do you think of a 4 bolt main #511 400 SBC Block ? Mustangsaly Engine 8 09-16-2012 08:30 AM
I picked up a 400 SBC and a M21 4 speed Mustangsaly Engine 22 03-05-2010 09:32 AM
427 sbc out of a 400 camaro409 Engine 23 08-02-2009 09:25 AM
400 SBC: Where is my torque?? ezobens Engine 51 01-01-2008 06:46 PM
My sbc 400 build up, please review Guitar Charlie Engine 13 06-17-2004 08:06 AM
