Windage tray clearance - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-03-2005, 07:32 AM
blacklotus's Avatar
Greg
Last journal entry: Wiring begins
How much clearance should there be between the crankshaft and a windage tray?
The tray is on a 351M/400 with a 7qt oil pan. There is a small amount of clearance, but I am not sure if it is enough.
Greg
Old 04-03-2005, 10:10 AM
lluciano77's Avatar
Short changed on common sense
WINDAGE TRAY INSTALL KIT
Required to properly mount the tray assembly. Adjustable mounting position allows the tray to work at its maximum potential by being as close as possible to the rotating assembly (min.100") and to avoid any unnecessary interference with the oil pan. Install with the 7/16" nuts torqued to 65 ft./lbs or 1/2" to 85 ft/lbs using oil, and the 3/8" nuts torqued to 35 ft./lbs.
Old 04-03-2005, 05:31 PM
blacklotus's Avatar
Greg
Thanks, I used a mounting kit from Canton and it had 1/2" nuts on the top and specified 20 ft/lbs and I torqued the main caps #2 & 4 to 105 ft/lbs per the engine specs. Anyway .100" is pretty close and I am not that close.
Greg
Old 04-03-2005, 08:10 PM
lluciano77's Avatar
I couldn't get my 400s windage tray that close either. I just got it as close as I could.
windage tray clearence 383ci roy383ci Engine 7 02-13-2005 05:14 AM
windage tray woes black66 Engine 2 10-12-2003 04:21 AM
Windage Tray Woes black66 Engine 1 07-01-2003 06:02 AM
windage tray 65galaxie500 Engine 8 04-08-2003 09:18 AM
Small block Chevy maint studs and windage tray hahndo17 Engine 2 03-10-2003 07:39 AM
