windage tray clearence 383ci - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-12-2005, 03:33 PM
roy383ci's Avatar
hi
a windage tray on a 4 bolt 383ci need this be
a stroker clearence tray or can i use one of a 350 ci
and what what kind of studs to use(400ci longer??)
thanks
Old 02-12-2005, 04:37 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
windage tray
Windage tray does nothing below 6500 rpm. How high you plan on winding this motor up?
Old 02-12-2005, 05:15 PM
roy383ci's Avatar
hi 5500rpm
i thought it is better for the balence of my crank
below 6000 rpm you have also oil splase
thanks for reply
Old 02-12-2005, 08:07 PM
302 Z28's Avatar
I disagree that the windage tray does nothing below 6500 rpm, but we all have opinions. One thing is for sure, it can't hurt IMO.
Vince
Old 02-12-2005, 08:45 PM
bracketeer's Avatar
489 Lemans
matter of opinion
Here is a thread with 70 postings on the pros and cons of windage trays. http://hotrodders.com/t55164-15--windage%20tray--1.html
Old 02-12-2005, 09:28 PM
NXS's Avatar
NXS NXS is offline
wind & fire = guides to power
Well my '97 vortec came with a windage tray factory and i'm glad. I've lost engines to air in the oil system and this will help. Not only that but they act as a girdle for the bottom end, added rigidity.
It's all about the denero. I would not put a set of aftermarket rods and crank in a block without one and an upgraded pan/oil system. Maybe there are guys who put aftermarket cranks, rods and aluminum heads on motors without them but they don't drive like i'm prone to from time to time. Half way thru an on/off ramp at 90/6500 rpm, it takes just a fraction of a second with no oil . Would a windage tray have saved not only an engine but an entire car? I'll never know but i think the answer is yes.
Old 02-12-2005, 09:32 PM
lluciano77's Avatar
SBC 400s and 350s require different windage trays. The Milodon Diamond Stripper I got was supposed to be the new and improved "universal" one. I still have to take out the Dremel tool and open up the holes more.
I think you will be alright with the 350 tray. If not, just grind it to suit.
Old 02-13-2005, 05:14 AM
roy383ci's Avatar
thanks for the info
bu i still dont got a good idee if it will
fit the stroke
and how about studs 4 hole tray 6hole tray
how many studs are there for a for a windage tray(arp 4 bolt set)
