Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Windage tray installation
Old 07-18-2008, 02:52 AM
SnottyAust's Avatar
SnottyAust SnottyAust is offline
GTS Monaro Coupe 406
Did the same myself once on a fresh block. Swapped out the bolts for studs without a prob.
Besides checking clearances after installing studs, put the caps on without the bearings and run your fingernail over the cap to block joining line checking for any edge sticking out. Should be dead flat and probably will be if it was before.
