IMO.... I don't think a windage tray is NECESSARRY, but 'free' horse power is free horse power..... (forty bucks for a windage tray isn't free..) I can't tell if my motor is any stouter for having one or not. But i'd like to think that is the reason i'm running as strong as i am
...... if you can, get a milodon tray, they come with yellow stickers, the KEY to HP.....the tray's basic function is to keep the oil off the crank, reducing aeration of the oil, and decreased drag (minutely parasitic) on the crank. The baffles keep the oil on the pickup. next............. |
As the name implies, a windage tray keeps the wind currents generated in the crankcase from pulling the oil up and into the rotating crank shaft. The bigger an engine and the higher the revs the more current is created. The oil is not as likely to be pulled away from the pick-up as it is to act as resistance to the rotating assembly, or simply take away some horsepower. I us a windage tray in every engine I build, and think it is a cheap addition, I suggest you install one. While it isn't as likely to pull the oil from the pick-up it can, as the rpms climb and oil is circulating, contribute to a low supply of oil in the pan.
From what I understand trays help to keep oil in pan/ scrape(not psy. of course) oil off the rotating assembly thus keeping rotating weight down allowing better rpm bands and gaining a few HP. The main job is to keep oil off crank. If you get one get a good one and not a solid tray one.
Thanks for all your input on my windage tray question. Canton sells a tray that goes with their pan and is sandwiched between the pan and the block. Seems this might be a leak potential but I haven't heard any bad press on the set up. Since I already have the canton pan I might as well use their tray too. Milidon sells the pan and tray combo but they said there could be Header clearance problems with the Milidon performance pans.
unless you have an leaky oil pan gasket you shouldn't have any trouble.windage trays that aren't part of the pan bolt in.you get studs longer than the bolts they replace so you can bolt the tray on after installi the crank.otherwise you would replace your cap bolts one at a time and retork them,then install the tray and nuts that hold them on.
