Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Windage trays
Thread: Windage trays
Old 09-17-2007, 06:09 AM
Kevin_Johnson Kevin_Johnson is offline
Originally Posted by GCD1962
My 70 LT-1 Short Block came stock with a windage tray. I also use a lifter valley baffle to keep hot oil off the bottom of the intake. Windage trays have proved their benefit for nearly 40 years in performance engine. It seems that maybe Crane is trying to cover "all the bases" for the poor cam blanks and lifters that are resulting in cam lobes being wiped out during break in. The LT-1 short block has been in my '62 Vette since 1973 and I have had zero problems. I had the heads and pan off last year while doing a frame replacement and the inside of the engine, including cam and lifters are still perfect after all the years.
There have been a lot of problems with the reformulated oils with respect to cam breakin due to the additives being restricted. Once the galling process starts, no amount of oil will stop it.
I read a lot of forums and have felt bad over how some reputable cam manufacturers had their names dragged though the mud by people who didn't realize the reformulation had taken place.
