windlace wrinkling problem - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 04-07-2012, 06:54 AM
DanTwoLakes's Avatar
Wiki Edits: 22
There is a 1/4" thick tacking strip held in place with metal flaps that you either staple or tack the windlace to.
  #17 (permalink)
Old 04-07-2012, 08:05 AM
Thank you, sir!
  #18 (permalink)
Old 05-27-2012, 10:20 AM
fat fendered fleetside
Heres a view of the car...
Name:	2012-02-25 20.08.2849139.jpg
ID:	65627   Click image for larger version
Name:	2012-02-24 16.08.3749140.jpg
The Following User Says Thank You to mordachai For This Useful Post:
kiWigrEEne (07-31-2012)
  #19 (permalink)
Old 11-28-2012, 04:13 PM
Last wiki edit: Stroker 351 W Ford Motor=Building
Ive seen some upholstery people just do a fold over to kill the wrinkles.
  #20 (permalink)
Old 11-30-2012, 05:53 AM
solidaxel's Avatar
Last journal entry: Project garage complete!
Originally Posted by bookm View Post
I think that looks great! I have the same problem on my '29 REO's sunroof, which was in place when I bought the vehicle. What I'm curious about is, what are you stapling to? Did you install some sort of wood surrounding the opening?
WELL THAT TURNED OUT GREAT.
We are getting ready to install a headliner in our strech cab 53 Chevy and when we were doing the finish metal work, we removed the strip that holds the inside rubber windlace.
The entire roof area is covered with 18ga. sheet metal, with insulation in between.
The question is the windlace AND the headliner material?
Do we start over and cover the roof with wood, or something to attach the windlace at the edges, or just contact glue to the metal?
YES this is a very helpful site with great folks, Thanks !!
  #21 (permalink)
Old 11-30-2012, 07:27 AM
Wiki Edits: 22
Can you take a picture of what you're trying to do? Windlace has to go on before the headliner goes in.
  #22 (permalink)
Old 02-03-2013, 05:35 PM
windlace question
What type of material is your windlace stapled to. I'am going to be doing my 56 Pontiac very soon and have seen what I took down, but not sure what it is. Doug
  #23 (permalink)
Old 02-03-2013, 10:13 PM
Wiki Edits: 22
The material you staple the windlace to is like a heavy cardboard (about 3/8" thick) that is held in place by metal tabs. If you took it out, you'll need to replace it.
  #24 (permalink)
Old 02-05-2013, 07:42 PM
AFX's Avatar
AFX AFX is offline
That is a gorgous car!!
  #25 (permalink)
Old 03-04-2013, 09:35 PM
Wow, that really came out nice. What a difference
  #26 (permalink)
Old 03-05-2013, 08:59 PM
adjusted nuts
I also had these problems years ago, but learned to cut the vinyl correctly. The stretch needs to go the length of the windlace , plus i did not want to have seams in it So i cut it on the BIAS and it worked great Makes for show quality .
  #27 (permalink)
Old 03-06-2013, 07:16 AM
Wiki Edits: 22
For those of you who don't know, cutting welt cord on the bias means cutting the fabric strips at a 45 degree angle. This means using up a huge amount of fabric, or having welts that have a huge number of seams. I'm not sure how you can bias cut anything longer than about 7 feet long without having to seam it.
  #28 (permalink)
Old 03-06-2013, 06:03 PM
adjusted nuts
Hey man, I have won many grand national bestt interiors awards. So it takes a little more material to make it almost perfect , so what ! You can cut it on the Bias at 15 feet and get wrinkel free, been hhere and done that! sorry if i cant explain as Dan does, just trying to help
  #29 (permalink)
Old 03-06-2013, 06:10 PM
You can cut material up the roll and get 15 ft but how are you going to cut it on a bias and get 15 feet off of a 54 inch roll?
  #30 (permalink)
Old 03-06-2013, 06:38 PM
adjusted nuts
It is not the exact Bias, but it will still stretch like the Bias , more material but less work. no wrinkels, 2 1/2 yards with vinyl. There is still a lot of vinyl left to work with. think about it , it only takes 2 strips 4 in wide
Paint wrinkling. off2wildblue Body - Exterior 8 03-19-2011 01:04 AM
HOK Kandy wrinkling normsf Body - Exterior 7 08-08-2007 08:52 PM
Windlace help 302 Z28 Interior 22 04-22-2007 03:10 PM
Craters and wrinkling Grusome Goat Body - Exterior 4 03-09-2004 09:18 PM
To windlace, or not to windlace... that is the question. phattpat Interior 11 01-29-2004 09:12 AM
