What did you sew the windlace with? If you didn't use a 3/4" welt foot on your sewing machine, ( assuming 1/2" sponge rod or 5/8" welt foot for 3/8" sponge rod) you will get wrinkles like that. Still, that is a very severe corner, and some wrinkling will probably occur no matter what, but it should be less than what you have there.
__________________________________ No one lives forever, the trick is creating something that will. __________________________________ |
I used a welt foot to sew it. maybe I might have to sew a dart like I did in the sharp 90 dgree corner, but was thinking there is something I am overlooking. Maybe a few more pics an someone will notice something I am missing.
Last edited by mordachai; 03-27-2012 at 09:02 AM. Reason: Added pictures from my phone, trying to resize them smaller |
This is just a thought, but how about taking the stitching out completely in the corner and pulling the vinyl as tight as you can?
I have a piece of cloth windlace here and it did the same thing when I bent it like yours, although not as severely.
I'm thinking this vehicle is a later 50's or early 60's, is that right?
I was also thinking that you could staple your windlace up to about 2" away from the corner, and then pulled it across the corner and stapled it down 2" away from the other side of the corner, and then pulled it up and away into the corner that that might work or at least help.
Yep, its a '59 ford wagon.
thanks for the advice. I ended up cutting out the stitching completely and stapled just the outer side and steaming and stretching it as I stapled it along the curve, then I did the same to the inner side. The end result is a whole lot better than what was there, not perfect but ok. . . thanks ![]() ]
That's about as perfect as you could expect, I think it looks great. I'm glad it worked out for you.
windlace
Looks a lot better. I think if you did the same on the straight parts away from the corner, 6 or 8 inches, you could possibly loose the last few wrinkles.
something when you cut you material make sure the stretch goes the long way cut.
you need the stretch to go the right way, as it will stretch one way might help |
I just learned something. Well, a couple of somethings.
Thanks Guys! |
I think that looks great! I have the same problem on my '29 REO's sunroof, which was in place when I bought the vehicle. What I'm curious about is, what are you stapling to? Did you install some sort of wood surrounding the opening?
| Recent Interior posts with photos |
| Paint wrinkling. | off2wildblue | Body - Exterior | 8 | 03-19-2011 01:04 AM |
| HOK Kandy wrinkling | normsf | Body - Exterior | 7 | 08-08-2007 08:52 PM |
| Windlace help | 302 Z28 | Interior | 22 | 04-22-2007 03:10 PM |
| Craters and wrinkling | Grusome Goat | Body - Exterior | 4 | 03-09-2004 09:18 PM |
| To windlace, or not to windlace... that is the question. | phattpat | Interior | 11 | 01-29-2004 09:12 AM |
