windlass troubles - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-12-2012, 08:15 AM
windlass troubles
does anyone know any tricks for installing windlass moulding. 51 chevy pickup it took me 1 1/2 hours to get two feet in i straightened the channel but it sure is a pain ay advice would be great, this stuff is going to make my head explode.
Old 02-12-2012, 11:29 AM
I'm not sure what moulding your referring to. If it is the moulding around windshield then you have to start by putting the moulding in the gasket first and then the glass goes into the gasket and then rope it into the opening. Use hand cleaner on the rubber to help it slide into place. If this is not what you are working on give me a better hint. Ed
Old 02-12-2012, 01:42 PM
rattle, it's the rubber moulding that goes around the door frame on the inside of the cab.
More Z-Bar Troubles Nova Doug General Rodding Tech 2 03-26-2007 08:17 AM
t-350 troubles fasttruck Transmission - Rearend 2 03-20-2007 10:07 PM
HEI troubles calvin dodd Engine 3 02-15-2007 10:49 PM
250 troubles shelby987 Engine 6 03-17-2006 12:57 PM
th 350 troubles gab Transmission - Rearend 8 01-17-2005 10:14 AM
