Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - window channel
Thread: window channel
Old 09-23-2005, 08:27 PM
willys36@aol.com's Avatar
willys36@aol.com willys36@aol.com is offline
Wiki Edits: 21
I just put rower window risers in the rear panels I built for my king cab '53 Chevy pickup. I made a Masonite window pattern and used it in the opening to position my guides in the proper position. Once I was happy that they were square with the opening and the window would slide up and down OK, I made some sheet metal "L" shaped brackets that I welded onto the channels and screwed to the body with sheet metal screws. Takes about 6 hands and eyeballs that can see around corners but with a little patience it can be done.
