window channel - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-23-2005, 07:21 PM
New Member
window channel
thanks in advance,this place is great.i just ordered window channel kits for my 33 ford truck from vintage ford and was wondering if any one had any tips on installing them? the windshield was installed by a shop in durham and the rear oval window is in good shape but i think i can do the door glass myself,if i can get the channel right,also would you go with tinted glass or not?
Old 09-23-2005, 08:27 PM
willys36@aol.com's Avatar
Wiki Edits: 21
I just put rower window risers in the rear panels I built for my king cab '53 Chevy pickup. I made a Masonite window pattern and used it in the opening to position my guides in the proper position. Once I was happy that they were square with the opening and the window would slide up and down OK, I made some sheet metal "L" shaped brackets that I welded onto the channels and screwed to the body with sheet metal screws. Takes about 6 hands and eyeballs that can see around corners but with a little patience it can be done.
Old 09-24-2005, 02:25 PM
New Member
Willy36
Thanks ,i Give It A Try
How do I remove widsheild/rear window trim from 65 GTO without damage? smallblocker2 Body - Exterior 10 06-24-2007 11:40 PM
firebird window channel rot mrcleanr6 Body - Exterior 3 03-31-2005 08:08 PM
Window channel problems.... onebadmerc Body - Exterior 4 03-25-2005 04:42 PM
Before I break it m-hauler Body - Exterior 16 07-20-2003 05:40 AM
window channel one off Interior 8 01-07-2003 07:40 AM
