Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - window channels
Thread: window channels
Old 04-03-2011, 05:46 PM
fiddyfofoad fiddyfofoad is offline
How do the rollers separate from the glass holder? The stationary roller that slides in the channel welded to the body is the only one facing out and I can see its spring loaded and I assume the other two facing away are the same, I can compress the spring and rotate the roller but even with a mirror, I can't see whats holding it to the pin, Joe
