Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - window channels
Thread: window channels
Old 04-03-2011, 11:48 PM
JeffB's Avatar
JeffB JeffB is offline
The two rollers in the bottom of the window track are EZ to remove,put your index and middle finger on both sides of the roller and squeeze inward and remove the clip and it will pop off the peg, when you have both of those removed you can slide the upper arm out of the track with the roller intact which makes it easier to reinstall by hanging it first and then reinstalling the bottom rollers,if your old rollers are original you may want to replace them the glass shop I went to charged $2.50 each.Obsolete Ford has the rollers part#BA-23240-70A 1(800)654-3247.
