window channels and felt - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-12-2007, 07:53 PM
TexasDan's Avatar
I'm building a replica h1 hummer. I need to get window channel molding and felt for the doors. I've looked at Soffseal, Precision, StanPro and nobody makes anything even close. My channel is 5/8" wide and 9/16" deep. The door has a lip on both sides of the glass for felt to be pushed on to. I'll post some pictures at my web site. www.ltw.net/windows this week end.
Old 01-13-2007, 08:08 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Have you tried Steele rubber Co.?
Old 01-13-2007, 08:17 PM
powerrodsmike's Avatar
Wiki Edits: 161
Metro is another good place to look.
http://www.metrommp.com/
Look at the "universal" parts heading, then "window channels and sweepers".
You will find stuff like this
Later, mikey
BE different....ACT normal.
Old 01-14-2007, 01:10 AM
Hey, you should be able to pick that up at Mossberg-Schleeter over near the Mangum/290 area. Check the phone book.
Old 01-14-2007, 11:28 AM
colormecrazy's Avatar
Paintshop Dog
Is that a T-REX?
Old 01-15-2007, 09:22 AM
TexasDan's Avatar
Thanks Guys,
I haven't found any one yet that has 5/8" x 5/8". I'll keep looking.
This is a Urban Gorilla. Same as is on Xtreme4x4. Watch the show on Feb 11 and 17.
Old 01-15-2007, 09:51 AM
Wiki Edits: 161
I thought you said 5/8 X 9/16?
Try Sommer and Maca or CR lawrence.
You will need to create an account on both sites, as they don't usually sell to the general public.
http://www.somaca.com/DefaultG.asp
http://www.crlaurence.com/ProductPag...h=::4375::4414
Here is some more of the stuff that cr lawrence has.
http://www.crlaurence.com/ProductPag...75&Path=::4375
If those guys don't have it, and it isn't an OEM piece then it probably isn't made. I can't imagine that the guys building those hummers would have specified something custom for window channels.
Later, mikey
Old 01-15-2007, 10:00 AM
TexasDan's Avatar
Thanks Mikey,
I did say that the first time didn't I. The depth is 9/16 to the top of the channel. If I can, I'd like for it to be 5/8, that way it sticks out a little and can give me some more glass contact.
I'll try the other places.
window felt in 1955 chev. dan.schatz Hotrodding Basics 3 12-31-2005 05:05 PM
