Window Chrome Trim Removal - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-16-2009, 04:11 PM
obx2ack's Avatar
ItStartsSomewhereInTheSku LL
Hello,
I can not decide whether or not to removal my chrome trim around the door windows of the Wagoneer. I would like to treat the rust behind them, but I do not want to risk damaging the pieces.
They are not held on by clips, but look like they were "molded" to the body. There are two small tabs on the ends of the top piece and it looks like if it is removed the side will come off. The problem is that they are "rolled" under and would need to be pry-ed off somehow.
Has anyone had success removing this type of trim and re-installing it without damage?
Thank you in advance for any help.
John
Old 01-16-2009, 09:09 PM
BMM BMM is offline
Is it actually chrome? My best guess is its probably anodized aluminum, in which case you can carefully bend a tab and see if that allows it to slide off. I would imagaine theres some sort of adhesive on there though, otherwise wouldnt they rattle like crazy with just those things holding the entire piece on?
Old 01-16-2009, 09:11 PM
obx2ack's Avatar
I removed the trim without any damage and thought that I would share my experiences. I do realize that there are many different specialized trim removal tools available. I researched many different tools and actually found a tool in my box that worked. I think it is a very old putty knife or scraper that was one ground down very thin. It did the job without having to spend extra money on a specialized tool. I will also add that patience is the key.
I carefully slid the knife between the trim and body and continuously worked the trim loose without prying until it "popped" off.
ID:	35648   Click image for larger version
ID:	35649   Click image for larger version
Old 01-16-2009, 09:22 PM
obx2ack's Avatar
bmm,
You are correct that it is not chrome.
(I picked the Grand Wagoneer as my guinea pig to learn on and I do not believe that there is a better teacher than this beast. I have learn a tremendous amount of general auto repair from this vehicle in preparation for something special one day.)
Anyway, this trim looked like it was molded to the body by machine at the factory. There were no clips, no adhesive, just folded around the body very tightly. It could not be slid off because the ends were folded around the body as well. I'm glad that I removed it because there was major rust problems underneath.
Thank you for your help and I hope that my posting maybe helpful to someone in the future.
John
Old 01-17-2009, 02:09 AM
BMM BMM is offline
Everytime someone does something there is something to be learned. Glad it worked out for you.
Stainless Steel Window Trim - Removal Tool 64Joker Body - Exterior 4 01-02-2009 02:31 PM
72 Nova Exterior Aluminum Window Trim Removal onefastoldfart Body - Exterior 1 12-25-2007 08:04 PM
69 bonneville vinal top belt trim removal question Bad Rat Body - Exterior 2 02-26-2007 02:32 AM
70 el camino under rear window bed trim removal hrd Body - Exterior 0 03-25-2006 12:11 PM
Chrome trim removal on 73 Mustang.... onebadmerc Body - Exterior 3 03-18-2005 09:01 AM
