Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Window Crank Extension's
Old 11-20-2011, 05:28 PM
Loppy Loppy is offline
Can't spell custom without CUS
Just finished a 6 year project. A 55 Belair Wagon. The custom interior panels are now thicker than stock, so I'm in need of window crank extension's. I've been told they were once readily available from JC Whitney and similar suppliers, but I've searched, and called them with no luck. I thought of extending the existing splined shaft with solid or hollow rod and welding the spline end at the end, buts thats the last resort. A set of 67 GTO convertible window cranks do clear because of the different handle angle, but these will be temporary, since I want the stock 55 handles. Anyone out there in know where to find the extensions? Thanks.
