Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Window Crank Extension's
Old 11-24-2011, 03:47 AM
Anastasia Anastasia is offline
What do you manual window people do for window cranks? The door X precludes the use of the stock window cranks, however, if I can extend the existing crank beyond the door tubes they will still work.
My non-scientific research shows that the window crank from my '75 BMW 2002 fits on the subaru, leading me to think that the spindles are one of those nearly universal parts. Does anyone know if this is true, and if so, where to get steel (weldable) window cranks so I can custom build a set? I was thinking of something like this.
At some point I'm going to retrofit power windows, but in the meantime I would like to be able to roll the windows up/down without opening the door
