-   Interior (http://www.hotrodders.com/forum/interior/)
-   -   Window Crank Extension's (http://www.hotrodders.com/forum/window-crank-extensions-209078.html)
Loppy 11-20-2011 04:28 PM
Just finished a 6 year project. A 55 Belair Wagon. The custom interior panels are now thicker than stock, so I'm in need of window crank extension's. I've been told they were once readily available from JC Whitney and similar suppliers, but I've searched, and called them with no luck. I thought of extending the existing splined shaft with solid or hollow rod and welding the spline end at the end, buts thats the last resort. A set of 67 GTO convertible window cranks do clear because of the different handle angle, but these will be temporary, since I want the stock 55 handles. Anyone out there in HotRodders.com know where to find the extensions? Thanks.
timothale 11-20-2011 06:18 PM
window cranks.
I don't know if the gear and shaft from other Gm products can interchange.or if other gm handles would work. I remember that when Mustangs and cougars were being built there were 105 different handles in the factory. leather interior padded panels use handles with different offset to clear the padding. cougars had heaver glass and the handles were longer than mustangs. After looking for missing handles on some of my projects I gave up and found 4 matching handles in the salvage yard that would fit the shafts.
Anastasia 11-24-2011 03:47 AM
What do you manual window people do for window cranks? The door X precludes the use of the stock window cranks, however, if I can extend the existing crank beyond the door tubes they will still work.
My non-scientific research shows that the window crank from my '75 BMW 2002 fits on the subaru, leading me to think that the spindles are one of those nearly universal parts. Does anyone know if this is true, and if so, where to get steel (weldable) window cranks so I can custom build a set? I was thinking of something like this.
At some point I'm going to retrofit power windows, but in the meantime I would like to be able to roll the windows up/down without opening the door
Blown'55 Buick 01-21-2016 12:39 PM
Window crank shaft extensions are available on eBay. They should fit.
DanTwoLakes 01-27-2016 01:38 PM
Where exactly can you find them on E-Bay? As far as I know, they are not available any more. I'm sure it's some kind of safety issue.
The only thing I've seen in the last 20 years, are longer shafts that require you to take out the window or door crank mechanism and replace the existing shafts with longer ones. http://midfifty.com/item.php?INV_ID=427&AD=1
Blown'55 Buick 01-27-2016 04:59 PM
Search eBay for "window crank shaft extension/spacer. Just looked and they are available today
69612 01-27-2016 08:34 PM
i ran across a stack of faucet handle extensions today... how many splines and what diameter.. probably won't work... they have been kicking around in my tool box for decades.. somehow they got into my nut and bolt bucket..
AMan31 01-28-2016 03:59 AM
Looks like it's only held on with a setscrew .
Window Crank Shaft Extension Spacer for Early Model Domestic Cars and Trucks | eBay
Blown'55 Buick 01-28-2016 04:20 AM
Have had these on my car for two years with no problem. If your worried about them loosening put JB weld over shaft first, but not necessary.
Tighten the cup ended set screw to recommended torque value and be done with it.
Or go but a TIG welder and weld a piece in.
Good luck
DanTwoLakes 01-28-2016 07:50 AM
Originally Posted by AMan31 (Post 3521857)
That auction is for one piece, which is not a big help. I know there are things like that out there, but I don't think they are manufactured any more.
DanTwoLakes 01-28-2016 10:51 AM
It doesn't say anywhere that I can see that there are more available, it says "last one" so I'll take your word for it. I meant there are no aftermarket suppliers making them any more.
