-   Interior (http://www.hotrodders.com/forum/interior/)
-   -   window crank info (http://www.hotrodders.com/forum/window-crank-info-204098.html)
retiredblue 08-21-2011 09:38 PM
window crank info
will GM Cranks fit Ford window stems- in other words will a 65 impala vent window crank fit a 65 Falcon window regulator? I need cheep SHORT cranks- its a looong story thanks in advance
DanTwoLakes 08-22-2011 06:59 AM
GM handles are held on with wire clips, as are your Falcon handles, but I don't know if the spline pattern or the stem diameter would be the same.
retiredblue 08-22-2011 07:52 AM
the Ford ones are also held on by a kinda horseshoe type clip- I was wondering about the spline- if they are compatible???
DanTwoLakes 08-22-2011 09:03 AM
That's exactly what I just said.
retiredblue 08-22-2011 01:00 PM
ok thanks i guess I'll see about the gm cranks then
retiredblue 08-23-2011 11:20 AM
OK i got the handles to fit correctly- and I stayed with the ford handles
