window crank info - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-21-2011, 09:38 PM
Last journal entry: fan shield
window crank info
will GM Cranks fit Ford window stems- in other words will a 65 impala vent window crank fit a 65 Falcon window regulator? I need cheep SHORT cranks- its a looong story thanks in advance
Old 08-22-2011, 06:59 AM
DanTwoLakes's Avatar
Wiki Edits: 22
GM handles are held on with wire clips, as are your Falcon handles, but I don't know if the spline pattern or the stem diameter would be the same.
Old 08-22-2011, 07:52 AM
the Ford ones are also held on by a kinda horseshoe type clip- I was wondering about the spline- if they are compatible???
Old 08-22-2011, 09:03 AM
Wiki Edits: 22
That's exactly what I just said.
Old 08-22-2011, 01:00 PM
ok thanks i guess I'll see about the gm cranks then
Old 08-23-2011, 11:20 AM
OK i got the handles to fit correctly- and I stayed with the ford handles
electric power window crank switch Hot Rod Mike Electrical 18 02-27-2012 09:34 PM
window and door crank mike strozewski Body - Exterior 1 12-26-2006 10:29 PM
window crank The Fox Interior 9 11-28-2006 02:20 PM
Looking for dice window crank knobs goth_rod87 Interior 1 09-27-2005 12:59 PM
how do i remove my vent window crank? efhill321 Interior 5 04-15-2005 03:37 PM
