Window Cranks - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-19-2009, 01:51 PM
Window Cranks
Hi, Has any seen a mechanism like this for a window crank? Seems to be after market (maybe) it is 1/2 inch od with 11 teeth. all the after market cranks have 16 or 32 teeth. I have tried them and they wont work , just hoping someone knows where I might be able to find some to fit before I cut these to fit. Thanks
Old 05-19-2009, 02:11 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Was there supposed to be an attached photo w/this post?
Old 05-19-2009, 02:30 PM
Yes they didn't go thru keeps saying upload error.
Old 05-19-2009, 02:54 PM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
you might try to down size the file, retake the picture @ a lower resolution /// less pixels then try it again ..
Old 05-19-2009, 03:01 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The limit on jpg files is 300MB, if you have the software like whatever came w/your camera or p-shop, etc, just resize.
Old 05-19-2009, 03:12 PM
JeffB's Avatar
EZ to use site
Try this:www.picresize.com Free & EZ
Old 05-19-2009, 10:29 PM
I think I got it here are just the splines a will take a photo of the mech tomorrow. Thanks
ID:	38250   Click image for larger version
Old 05-20-2009, 09:25 AM
bobjob's Avatar
what kind of car? looks like something off old car. maybe check with some reproduction parts places.
Old 05-20-2009, 09:56 AM
Its on a 32 ford 5 window, but its an old 70s fiberglass body.
Old 05-21-2009, 07:46 AM
powerrodsmike's Avatar
Wiki Edits: 161
You can put a stock type reproduction window handle if you file the shaft so it has a square end. The stock handles on those era cars had either a cross pin that was a snug fit, and held in by the escutcheon, or a screw through the handle that went into the end of the shaft..Are you looking for a repro or fancy handle?
A description of the actual mechanism would be helpful in determining which way to look for handles. There were aftermarket suppliers of universal mechanisms to the body manufacturing industry. Folks also installed whatever they could find , as many of those 'glass bodies came with no hardware for windows.
Later, mikey
BE different....ACT normal.
Window cranks for a 72' Chevelle? nitro3421 Interior 9 01-21-2016 08:40 PM
Window cranks on 72' chevelle? nitro3421 Hotrodding Basics 1 08-06-2005 12:18 PM
removeing window cranks and door handels 51FordDuff Interior 6 10-20-2004 08:38 PM
those damn window cranks bigpimp2988 Interior 6 09-11-2003 06:15 PM
Before I break it m-hauler Body - Exterior 16 07-20-2003 06:40 AM
