Window cranks for a 72' Chevelle?
I'm changing out the door panels on my 72' Chevelle and cant get the door cranks off, are they just pressure fitted on there?... Can anyone help me?
Thanks Scott |
no, i havnt removed the clips, are they directly behind the round part of the crank?
thanks for the help!
You can make your own with an old choke or throttle cable, the stiff wire type, bend a small hook on the end, hook the loop on the clip and pull straight up. Dan
old hacksaw blade
Grind all the teeth off, so you don't damage the trim panel. Grind one end of the blade, making a fairly large notch until you reach the outer edge of the hole. Bend the remaining material slightly, so that it will sprung out just a little. Insert the blade between the washer and the handle, and "hook" the closed end of the clip. Pull on the blade, and voila! |
Here is a SNAP ON tool......#A159.....but most of the parts stores sell a cheaper model ......for a few bucks.... DEUCE......
"I won't be wronged . I won't be insulted, and I won't be laid a hand on. " |
| Recent Interior posts with photos |
| Window cranks on 72' chevelle? | nitro3421 | Hotrodding Basics | 1 | 08-06-2005 11:18 AM |
| 72 chevelle vent window parts? | 73chevyhelp | Body - Exterior | 2 | 04-07-2004 03:55 PM |
| 72 chevelle seat question | JamesRS | Interior | 1 | 03-21-2004 11:47 AM |
| 72 chevelle rear ends | 406chevelle | Transmission - Rearend | 10 | 02-15-2004 10:22 PM |
| 72 chevelle | 2wld4u | Suspension - Brakes - Steering | 1 | 07-22-2003 05:30 PM |
