window and door crank - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-26-2006, 08:06 PM
How the heck to I get the inside window crank and door handle off a 1929 four door sedan?
Old 12-26-2006, 10:29 PM
This is a Ford right? It has a pin going thru the crank and handle behind the excushen (sp?) bezel thingie. Push it in over the shaft and you will be able to see the pin. Using a drift punch and a hammer you can get it out.
