window guide rollers - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-06-2005, 08:28 AM
msc66's Avatar
Last journal entry: pics
I hope this is the right forum for this.
I bought some replacement 1/4 window guide rollers for my '66 Skylark but the shafts are so tight in the rollers that they don't roll. Are they supposed to or do they just slide through the channels? The old ones roll but they are so worn out and floppy that the windows dropped down about a 1/2 inch at the front and wouldn't line up.
Thanks for any help
Mike
Old 12-06-2005, 09:23 AM
It's more of a guide than a roller. Put some light grease on it and it will work just fine.
Bob
Old 12-06-2005, 10:39 AM
msc66's Avatar
Thanks Bob.
Old 12-10-2005, 12:35 PM
msc66's Avatar
'nuther question
When you say light grease what do you mean? When I took it apart everything had lithium grease on it and it was all hard. Is this still the best choice?
Also, do you know what grease to use to pack in around the drive gear on a power window motor?
Thanks
Old 12-12-2005, 06:55 AM
White lithium grease is what I use.
Bob
How do I remove widsheild/rear window trim from 65 GTO without damage? smallblocker2 Body - Exterior 10 06-24-2007 11:40 PM
gbody window blues madhat Body - Exterior 1 04-22-2004 07:56 PM
Power Window Problem Steven_O' Electrical 2 03-29-2004 01:09 AM
Before I break it m-hauler Body - Exterior 16 07-20-2003 05:40 AM
Rollers on a 350 with no guide plates? Zeder Engine 3 07-10-2003 11:33 AM
