window lever - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-25-2011, 06:06 AM
Last journal entry: some stuff
window lever
Hi, I'm in the middle of a '37 chevy restauration. While removing the interior,
I came across a problem. I can't see how the window levers are attached to
the door. I want them to remove so I can put them back in their place as soon as the interior is done. Can some one tell me what the correct procedure
is form removing these things?
Old 12-25-2011, 08:10 AM
DanTwoLakes's Avatar
Wiki Edits: 22
The handles are held on by a spring "C" shaped clip that sits in a groove. Here is a thread that explains the process: CLICK HERE
th 400 1-2 upshift w/lever in 1st grayghost52 Transmission - Rearend 3 07-05-2011 10:38 AM
Lever Shocks LS-57 Suspension - Brakes - Steering 2 01-14-2011 08:58 PM
Convert multi-function signal lever to plain lever? murrsue General Rodding Tech 0 03-07-2005 08:56 PM
Lever Shock is in the way! rwruther Suspension - Brakes - Steering 0 06-11-2004 03:20 PM
What is a kickdown lever for? kemo Transmission - Rearend 3 02-10-2003 10:44 PM
