Window regulators-39 Chevy - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-20-2005, 07:22 AM
Beenaway2long's Avatar
or Jeff, or Doc, or...
Last journal entry: Results of the Camaro
Anyone have ANY idea how to remove the regulators and windows in a 39 Chevy? I'm stumped.
Old 10-20-2005, 07:44 PM
jcarter's Avatar
Been watching to see if anyone gave any help.Where are you having the trouble with them?I will be taking the glass out of my doors soon and wasn't looking for any extra grief.I took the back windows out-- in a 2 dr.--- last year when it went on to the rotiesere, and they were easy to get out. Jim.
Old 10-21-2005, 07:24 AM
I got them out last night. Wooof, not fun with a 66 year old car.
First thing is remove the garnish moulding. Then remove the divider between the wing window and roll up window. 2 screws at the very top, accessed by rolling the window down, and removing the channel felt , Then remove the stud/nut about 8" below regulator. Remove the separator channel completely. Then rol the window down to where you can see the lower window channel. 4 screws (2 groups of 2) remove the channel from the horizonal regulator riser. Roll the window almost out, tip it out, and finish pulling it out. Because the grease/dirt form 66 years, you may have to pull the wheels from the X out of the riser channel.
Then it drops out the bottom of the door.
YOU HAVE TO REMOVE THE SEPARATOR CHANNEL. The channel goes behind the regulator, and wond allow the splines to pass inside the door. The handles have the same type clip than the 60's cars had.
Old 10-21-2005, 11:32 AM
jcarter's Avatar
Thank's for the detailed instructions.I'll be looking back at them latter.Seen where you are getting your top chopped, and not by some novice. How much were you taking out? Keep us posted in your journal. Jim.
Old 10-21-2005, 11:33 AM
3" front/ 2" rear.
Its a 2 dr sedan. I am also deleting the wing window, and going with 1 piece electric windows.
Window Install + Chevy Pickup SKELLY12 Hotrodding Basics 1 06-20-2005 06:38 PM
Window Install + Chevy Pickup SKELLY12 Body - Exterior 1 06-20-2005 03:23 PM
Thinking of buying a disassembled 39 Chevy jpd37 Hotrodders' Lounge 12 06-14-2005 11:10 AM
tailight options for 39 chevy body? jcarter Body - Exterior 1 03-04-2004 08:41 PM
37, 38, 39 Chevy trunk hinges "Warning" Ed Baltera Body - Exterior 0 05-19-2002 04:00 PM
